TC_Z's avatar
TC_Z
How to Install a Velvac 709645 Flat Glass Mirror
We have a 2007 Winn Voyage. The passenger rear mirror and support plate fell out when we hit a bump on the highway (construction). We chose not to try to retrieve it. I have ordered the replacement part, a Velvac 709645 Flat Glass with support plate. So far I have not been able to find any instructions how to install it. Not sure if I am supposed to attach the heater wires and then the whole thing snaps in place.
Or if I'm supposed to remove the clips and remove mirror from the support, snap in the the support, attach the heater wires and then reattach the mirror and clips.
Or something completely different, can't be too complicated, just don't wont to break the new part.
I checked all of the Velvac downloads, none seem to address my situation, the titles are misleading.
Has any one dealt with this before? If not I may have to call Winn or Velvac. Always fixing something....
  • You were right, worked perfectly! Many thanks!
    Not sure why removing the mirror from the support plate and screws were ever suggested.
    Appreciate it, thank you....
  • Based on my poor memory of doing this repair, I'll try to help.
    Look at the pictures in this ebay listing:
    ebay listing velvac 709645
    If you look at the second picture in that listing, you'll see the back side of the backing plate. The circle part of that backing plate will snap into a circular mount for the motorized function of mirror adjustment. (It snaps into what wa8yxm above called the "trolley".) The four screws are in the part that the backing plate snaps into.
    From your description, I do not think you are replacing anything but the mirror and the backing plate and will not need to remove those screws.
    Fred
  • I posted this.
    No instructions came with the part. I contacted the RV part supply and they said:
    "It's the same as these instructions except your mirror head has 4 screws underneath holding down the backing plate of your old glass."
    Velvac Glass Replacement Instructions
    See link. I am still confused, what screws?
  • Valvac sends full instructions with their replacement glass and the heater comes with the glass.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    It Depends a lot on how much of the mirror hit the ground.
    If it is a remote power adjust.. Did the adjustment "Trolly" stick around? IF so you can attach the wires and snap it in place
    If not then you first install the trolly.. THen attach the wires and snap it in place
    You can also remove the glass from the frame (how is fairly easy though they do put a dollup of glue on one corner) put the entire frame together, then attach the wires as you put the glass back.
    Doing this myself this week.
  • I'd wait, if its the supposed correct exact replacement and see if there is documentation or an instruction sheet with the mirror before putting too much effort into researching it.
    That mirror on Amazon comes with the heat element and inner housing so it should have the instructions.
