Bruce_Brown
Apr 06, 2015Moderator
hotjag1 wrote:FIRE UP wrote:
Hotjag1,
Just wondering Sir. May I ask, what would be wrong with creating a couple of "ramps/blocks" that, would allow you to drive on them, on the left side, to "pre-level" the coach so that, your jacks would not have to work so hard in leveling the coach? I do that all the time when out in un-level camp sites. This way, the coaches NATURAL stance, is primarily achieved without over working the jacks and therefore, you may, eliminate torqueing the frame which, may have detrimental effects on the body and windshield. Just some thoughts here.
Scott
I did mention at the end of my post, that I had filled in the low spot where the rears wheels sit, so now the MH is level when parked without using the jacks. I thought the reason for having jacks was so there wasn't a need to have to mess with wooden blocks. As you suggested, I guess that is going to be necessary if the site is fairly off level, unless I am not leveling correctly.
Since the coach was only low on the left side, I just put the left side jacks down. The right side jacks were not in contact with the ground. I'm wondering if that is what caused the problem.
That could be part of the problem.
Jacks need to be used in series to keep everything square.
On our current coach with automatic jacks, all 4 jacks deploy and touch the ground before any leveling starts. If, for example, the left side is low after all 4 jacks are down it will start lifting the left side coach a little, stop, then lower the right side to allow more lifting on the left. This keeps movements slow and the coach square.
And yup - 15 years ago I popped out a windshield too not keeping all 4 jacks down. :S You have to run them in pairs.
