ketchjb's avatar
ketchjb
How to prevent dead starting battery in storage?
I have a 2012 Class C (Thor Four Winds) with a Ford E-350 chassis. After sitting for 3 months in storage (shame on me) I found the starting battery completely dead. I assume there are 'things' that discharge the battery over time? I was able to start the rig with the emergency start switch from the house batteries. Now I have it on the charger hoping that there is no permanent damage.
The question is: how to prevent this in the future? I could:
A) disconnect the starting battery while in storage (not sure if that would cause other problems)
or B) I have a 100 W solar panel on the house batteries - maybe I could hook that to starting battery as well? But how? direct wiring to the starting battery or maybe to the cigarette lighter? For some reason I kinda don't want to mix the house and starting batteries.
or C) put a separate small solar panel up for the starting battery? (I kinda hate to do that - can't just put on the dashboard cause I use a vinyl cover on the windshield)
Note that I do not have access to 110V in the storage yard.
My old 1998 Jayco E350 never had this problem. I never worried about the starting battery.
  • I put a knife switch on my engine battery. Solved the battery drain problem.
  • I disconnect and check the voltage every month or so. If it went below 12.5 I would put a charger on it, but it never does.
  • Hi,
    Add a Trik-l-Start. Problem solved.
    There will have been damage to the starter battery--but likely it will remain useable for some time. Desulphate it, if you have the facility to do so.
  • Get a battery disconnect installed right at the battery.
    The electrical battery disconnect should be leaving some power to the chassis computer. It will eventially drain battery.
  • I have a switch that goes to either "use" or "store". Mine stores unheated, inside when not in use so the solar cells on the roof do nothing. It starts every Spring for me.
  • Harbor Freight sells a solar battery maintainer with suction cups. Maybe you could find a piece of glass that gets enough light to keep your batteries up to par.
