dougrainer
Jan 14, 2014Nomad
Do NOT take the wood panels off as they are probably glued in place. Remove all 4 doors if a 1200, you can remove all 4 doors in less time than it takes to remove the wood panel inserts. This makes the refer extremely lighter to remove from the cabinet and also free's up hallway clearance if close to the opposite wall. Remove both doors if a 2 door. Once you remove the doors you will see either round screw hole plastic caps on the top and bottom (newer 1200) or you remove the top and bottom 1 inch wide fascia plastic cover to expose the screws. 1200 have 4 on top and 4 on the bottom. Doug
