- wvabeerExplorerI have used this to repair torn fabric. I don't see ant reason why it wouldn't work with that.
https://www.walmart.com/ip/Tear-Mender-Bish-s-6-Ounce-Original-Tear-Mender-Instant-Fabric-and-Leather-Adhesive/17338063 - DSDP_DonExplorerCall Elements and see if they'll warranty it. Elements is now challenging Adco for their top spot in covers. Adco has been giving one new cover under warranty when theirs tears. Once yo receive the new cover, the warranty is over. So basically two for one. My neighbor just went through this with Adco.
- twainharteartisExplorerI found some patchs that came with the cover and used them and some duct tape and it worked good. thanks everyone.
- KansasRVExplorer
mike brez wrote:
works for everything! - Dick_BExploreror marine sail repair tape. I'd put in on both sides of the rip.
- starcraft69Explorer
mike brez wrote:
And use a heat gun to set the glue - Tyler0215ExplorerAny sewing machine will work. You just need enough room to lay the cover out.
- babockExplorerModesto is a little more than an hour away. I am sure there are some canvas shops there.
Or...buy an industrial sewing machine and learn how to sew! - mike_brezExplorer
- Dave_T_ExplorerI ordered ADCO sticky patches. I cut to size and then sewed them around the edges and across the tear using heavy duty nylon thread and an upholstery needle. I am on the third year in the Midwest after repairs. Not pretty, even Frankenstienish, but it works. I also pad the sharp areas using water noodles cut to size.
38,749 PostsLatest Activity: Apr 29, 2023
