dougrainer
Apr 13, 2017Nomad
5.5KW GENSET WILL RUN 2 AC UNITS. The ONLY switch for running 2 AC units off either Genset or 30 amp shore power was a system called the "Pulse Air". What this did was allow both AC's to run alternately. The system would not allow BOTH AC's to run at the same time, but if one was off the other could then run. It also allowed you the option of running wither genset on Shore or Genset if your Genset(less than 5.5)could NOT run two AC's. I do not know if they still market this aftermarket system. There is nothing that can be added to a too small genset to run 2 RV ac's. Doug
38,766 PostsLatest Activity: Jan 10, 2026
