Busskipper
May 28, 2017Explorer
bzboy wrote:
2017 Winnebago Vista LX. There is a plastic trim piece that runs front to back of the RV on the exterior. A section of it has separated from the wall. I can see it was held by double sided sticky tape on the inside. I have tried gluing it back and also tried 3M double sided tape but nothing has held. I think the expansion in the heat makes it difficult.
My next idea was to put one or two screws into the plastic trim and attach it directly into the wall but I'm hesitant to do that.
Does anyone have any suggestions or thoughts? Thank you.
3M makes a contact cement for that - need to get it CLEAN then re-glue - clean means CLEAN - or it will not stick. Just go to a good NAPA or auto supply store they should have it.
Best of Luck,
