rondeb
Aug 14, 2014Explorer
JimM68 wrote:
is this a common problem??
I'm looking at putting mcd's on the windshield, don't really have a problem with the side window pleated day-night shades...
The MCD shades on the front of our windshield is in a track. I do not know if all of them are. But you can't lower the front shades very low when the engine is running (safety) You will not have the issue above if you install the track. The above issue is for when you are traveling down the road and you lower the side window shades to block sun. The movement of the RV makes them bounce away from the window and when they come back in they hit the window making a noise. Something on the inside of the corners of the shades stop it.
38,766 PostsLatest Activity: Jan 10, 2026
