Old-Biscuit
Nov 04, 2014Explorer III
RVA Jeff wrote:
I realize that...I just meant I would look for a switch out there in general. Thanks for the help
There would not be any switch in outside compartment.....it is an Atwood and would only has a switch out there if it was a Suburban with electric & gas.
'Hot Rod' & 'Lightning Rod' are two aftermarket brands of electric heating rods that replace drain plug.
Yours being an Atwood you don't have the issue of anode rod like Suburban Brand.
The 'kit' comes with it's own set of t-stats.
You just have to supply 110V AC outlet to plug into.
Install the t-stats and then heater rod in drain hole.
Work OK..just a lot slower as the heat element is small and low wattage. (400W vs OEM 1500W)
38,779 PostsLatest Activity: Jun 16, 2026
