- korbeExplorer
korbe wrote:
RoyF wrote:
The hot water heater on propane will make a "roar" and there will be hot exhaust gas coming from the heater on the outside of your class C.
And while outside noticing the roar, and feeling the heat, go ahead and open the outside door and take a peak and see how its heating. Part of the learning process. On shore power, an electrical heating element inside the tank is heating the water (if switched). Two completely different processes. - korbeExplorer.
- RoyFExplorerThe hot water heater on propane will make a "roar" and there will be hot exhaust gas coming from the heater on the outside of your class C.
- powderman426ExplorerGo outside and open the door. Inside is a model number. With that you can look up the info on line.
- dennyidaExplorerOn our 2004 granite ridge we have two switches on our control panel, one for gas and one for electric. When we are plugged into camp power we can use eather one. Gas seems to heat faster
- tenbearExplorerThe gas will make a noise when it is starting that you can hear before the fan starts to run. Electrical is silent. If yours heats with electricity there will be a switch somewhere.
38,779 PostsLatest Activity: Jun 16, 2026
