APRSRVer
Mar 16, 2014Explorer
Circuit breaker for headlights is in headlight switch. If you have voltage for headlights out of the sw look for dimmer sw. Many are low on steering column operated by a rod down from lever on column. Or it may be a combo sw with wipers in column below steering wheel. I'd use a mechanics test light and probe the wire connector at the base of the steering column for a light that comes on with headlight sw and changes with operation of the dimmer sw. If that proves to be ok then the problem is between there and the headlights.
38,769 PostsLatest Activity: Mar 29, 2026
