skrams's avatar
skrams
Hurricane 34B Levelling Jacks
We just took our Hurricane 34B out of winter storage. The control panel for the leveling jacks mysteriously has no power going to it.
The slides operate without any issue.
Is there a specific fuse for the leveling jacks control panel? I am not sure that there is but figured I would ask anyway.
  • Thanks for the suggestions. I will check for fuses tonight when I get home. I know there are none in my battery compartment so all I have is under the hood.
    I tried all the simple things I could think of - emergency brake, fully charged battery. Hopefully I can pull a fuse tonight and all is good again.
  • Just keeping with the KISS method.... my stabilizers won't operate unless the emergency brake is engaged. I forget from time to time and then get a Homer Simpson "DOH!" moment right before I push down the e-brake.
  • Pull the slides in, engage emergency brake, start engine and then see if you have power.
    If you still have no power try this. In the battery compartment there are to circuit breakers. There is a 50 amp near the front and a 100 amp way in the back. Its probably the 100 amp that's open.
    There is also a 50 amp in the engine compartment near the starting battery.
