Tom_Barb
Sep 16, 2021Explorer II
HWH 610 Leveling system.
Our Jacks will deplete the air when the system is activated, then quit.
ignition is on, Acc.,, brake set, ground is nearly level.
you push the ( ON/Auto ) the control panel will light, and the red light will illuminate, the air will dissipate. ( go to 0)
then the pump will not Start as usual. you can hear the solenoids click as usual. but no pump noise or pumping action.
key pad shows a yellow light on the pad.
