dougrainer
Jun 04, 2014Nomad
rvten wrote:
OK I stand corrected on the slides? So it really makes no diff. Slide in or out. Just the Jacks.
It does make a difference ONLY if you intend to fill the reservoir to the very top. By leaving that 1 inch below the top, you are assured that you will not blow any fluid out when checking, slides extended or retracted. You have the margin of safe error. You can verify when the oil level is higher or lower, by noting the reservoir level with jacks retracted and the room Retracted. Then extend the room/s only and see how much lower the level goes if at all. Doug
38,774 PostsLatest Activity: Apr 26, 2026
