cbeierl
Mar 22, 2015Explorer
azpete wrote:
doug is correct about the rooms. if your coach has below the floor mechanisms, the rooms have to be retracted. if they have above the floor mechanisms, the rooms have to be extended. jacks should always be retracted.
in any case. one inch below the top of the tank is the right fluid level. if you're not sure, check it with the rooms retracted. that normally good enough. it doesnt have to be that accurate. just dont overfill.
Listen to 'azpete'--he works for HWH and knows what he's talking about.
38,774 PostsLatest Activity: Apr 26, 2026
