want-a-be's avatar
want-a-be
HWH Hyd. Slide Out Rails
We have a 2013 Phaeton with HWH Hyd. Slides. The problem we are having is the slide out rails are close to the body of the RV. I am in the process of changing the slide out pads but they are not that worn. Wanting to know how to bring the arms up to get them away from the body?
Thanks for all comments!
  • Do they touch or scrape? That is a common sight on your model Slide room on Tiffins. I would not worry about it unless it starts to scrape. Doug
  • You might try the TIFFINRVNETWORK site to see what the manufacturer says. the RVTECHLIBRARY there has DIY steps for adjustments.
