mtrumpet
Aug 11, 2015Explorer
Dachristianman wrote:
Display panel lights up showing my front being low (which it is). I push the up button, and the "jacks extended" light on the dash comes on, but then goes out as soon as I let off the button. If I push any of the "up" buttons, nothing happens, motor doesn't run. Only when I push the down buttons does the motor(s) run. I'll check out the Technical Manual link in the post above.
Tom
That is because your jacks are spring return. Pushing the "up" button merely opens a (solenoid) valve allowing the fluid to return to the tank as the springs are pulling the jacks up. There should be no motor running in the "up" position.
38,782 PostsLatest Activity: Sep 01, 2026
