Ernie8
Sep 04, 2013Explorer
HWH Jacks
My HWH one front and one rear opposite sides will not come back up on there own. Any info on what could be the cause. I check the fluid with the jack up and it show right on the first line. Should i...
DailyDriver wrote:
When I was in college (eons ago) I worked in a factory that manufactured hydraulic cylinders. I ran grinders for the shafts, dipped them in the chrome vats, and polished the shafts after chroming. I can tell you that chrome is amazingly porous, and is quite susceptible to rust forming beneath the thin chrome veneer. I suspect that any problems with the jacks retracting may be due to a rough surface from slight corrosion forming. This can be removed with very fine steel wool, then apply a protective coating.
If you are going to have the jacks extended for any length of time, it would be advisable to coat them with something for corrosion protection. WD-40, other forms of silicone, ATF, motor oil, anything to coat the surface and prevent corrosion will eliminate problems. This is especially important in any humid or other environment that has a high corrosion potential. The molecular film of oil on the smooth surface after extending the jacks will last for a period of time, but eventually will need something to extend that protection.
