happy-2 wrote:
If you can get all jacks up check the fluid level FIRST.After fill up run up then down a few times. also check the springs, mite have a week spring, a spring is cheeper than a cylinder.
OK lets check off your response
1. WHAT does fluid level have to do with HWH jacks failing to retract????
2. Springs can be a factor but NOT if they are still installed and not broken. Springs(new style tapered ends) will bring the jacks up FASTER, but a weak older style spring will still retract a GOOD cylinder. You can push (retract) a HWH cylinder with moderate pressure from your hand with no springs attached. Doug
