zigzag03
Aug 05, 2017Explorer
HWH Levelers
2003 Challenger 347 with HWH 210 Series levelers. Single action spring retracted pistons. Have to pry the fronts up, but they will go down with authority and am able to level the rig. Once asked to re...
zigzag03 wrote:Gjac wrote:
I still have the old style springs on mine and they work fine with some silicone spray once a season. Sometimes when I hear a creaking sound that is an indication that it is about to stick. It is only the front left that does this. The points that Bud was talking about are the roller and small cylinder that need to be cleaned.
And where specifically are these two components? Are they part of the control panel?
As to which lubricant, I've been in the marine field for almost my entire professional life, and rarely had a use for silicone spray vs the WD40-type. except when lubricating o-rings. I also use silicone grease when putting together pool equipment components, for instance. For petroleum based lube, I like one called Corrosion Block, from H&M. But if the goal is to loosen up tight seals, maybe silicone has an advantage. Since I have two tight cylinders, I'll try one of each and report.
