zigzag03
Aug 05, 2017Explorer
HWH Levelers
2003 Challenger 347 with HWH 210 Series levelers. Single action spring retracted pistons. Have to pry the fronts up, but they will go down with authority and am able to level the rig. Once asked to re...
AllegroD wrote:dougrainer wrote:AllegroD wrote:
HWH Maintenance.
ml47149.pdf
HWH FAQ
ml35963.pdf
It is also possible that your shafts may no longer be true.
How did you come up with that? In 30 years of working on HWH jacks, I have NEVER seen a bent cylinder. OTHER brands yes, NOT HWH. Doug
Doug, On our previous MH, we were on a steep slope and the front wheels came off the ground. Coach moved to the side before I could drop it down. The yaw to the side is what alerted me. Had to use a shovel to pry that leveler up until we got it pulled and sent back to the factory.
