dougrainer
Jun 19, 2014Nomad
You are not explaining your problem correctly. From your post you seem to state that you DID get the jacks up by opening the T handles. Is that correct? If ALL 4 jacks would NOT come up unless you released the T handles, but all 4 jacks WILL extend with the T handles closed, then the SHUTTLE valve needs replaced. Explain all the parameters more fully. Doug
38,769 PostsLatest Activity: Apr 04, 2026
