dougrainer
Aug 01, 2014Nomad
ROADSTARJR wrote:
Ok I have closed values "clockwise" and jacks don't work at all, pump sound like is under load with in 30 sec.
OK, now open all 4 valves and see if all 4 extend. If so, you either have 4 burnt out solenoids or NO power to the solenoids when in operation. The easiest way to check for power to the solenoids is to put in store and then check the 2 wire harness at each valve for 12 volts. White wire is ground and black will have 12 volts. you have 6 minutes to check before the system times out. IF you have voltage to the solenoids and they operate when manually released, you have 4 burnt out solenoids. Doug
38,769 PostsLatest Activity: Apr 04, 2026
