usersmanual
Sep 19, 2016Explorer
Monkeyrun wrote:
Today I pulled our Allegro Bus out of the barn and washed it, along with that I power washed the leveling springs to clean them before lubrication. I then attempted to extend the cylinders in order to clean/inspect and lubricate, however, the only thing that happened when I pushed the air down button is all the indicator lights lit on the box. I tried turning all power off, key on accessory and ignition positions, nothing changed. The "off" button does turn all the lights back off.
The mechanism worked fine in April, I'm wondering if the water created a problem at a sensor. It never crossed my mind while spraying them down as those are exposed under the vehicle and subject to the elements. It's back in the barn now so by morning everything should be dry.
why would the springs need cleaning and lubricating? the only sensors are the jack down ones they get wet driving in the rain I would assume?
38,782 PostsLatest Activity: Aug 31, 2026
