sdianel_-acct_c
Sep 19, 2016Explorer
What year is the Allegro Bus? We don't have an Allegro Bus but there is usually a fuse near the pump. Found this on another post: "This may or may not help, but on my 2012 Phaeton there are 3 fuses visible around the HWH pump. As you look at the pump motor from the end, there is a relay on each side. The relays are connected by a heavy (probably #2 or #4) wire. The 40A fuse is on a wire that is connected to the same terminal as the large wire on one of the relays. The fuse is only about 6 inches from the terminal. I missed it at first because it was tucked under the pump.The other 2 fuses are 15A."
38,782 PostsLatest Activity: Aug 31, 2026
