usersmanual
Sep 20, 2016Explorer
Monkeyrun wrote:
The box has power but perhaps there is an issue elsewhere. Sounds as though I have some extensive troubleshooting to do before our upcoming trip. In the event I run out of time, is there a way to manually operate the cylinders in order to stabilize the coach? I believe I can dump the air with the air fitting under the hood.
two things.1) I once had a air level system flash the control lites and it was a blown fuse.this was in a beaver contessa
2) try disconnecting the touch panel and reconnect
3) no way to manually lower them only to release(lift) them
38,782 PostsLatest Activity: Aug 31, 2026
