wallynm
Sep 20, 2016Explorer
There may be some certified technicians located around the country that can repair your unit.
look here
look here
dougrainer wrote:
According to HWH, IF the ground connections are good and you have 12 volts plus to the Control box, the odds are either the Control box or Touch pad is defective. The bad news is, those parts are no longer available. You will have to send both the Touch Pad and the control box back to HWH for them to rebuild them. IF the control box is still by the drivers inside wall by the steering column, they would want the control cable between the touch pad and control box sent back also. Doug
38,782 PostsLatest Activity: Aug 31, 2026
