dougrainer
Sep 20, 2016Nomad
wallynm wrote:
There may be some certified technicians located around the country that can repair your unit.
look here
dougrainer wrote:
According to HWH, IF the ground connections are good and you have 12 volts plus to the Control box, the odds are either the Control box or Touch pad is defective. The bad news is, those parts are no longer available. You will have to send both the Touch Pad and the control box back to HWH for them to rebuild them. IF the control box is still by the drivers inside wall by the steering column, they would want the control cable between the touch pad and control box sent back also. Doug
1. I am a Master Certified Technician with 37 years experience
2. I am HWH factory trained
3. If I state what needs to be done, that is what needs to be done:B
4. I also work on Tiffin (still do) for that 37 years. Doug
38,783 PostsLatest Activity: Sep 23, 2026
