Jim@HiTek wrote:
Working on a '04 Winnebago Journey with the HWH leveling system. This hydraulic Jack and Room Slide system is mounted under the stair well and most of the equipment is accessed there. The main control box faces forward and has a clear plastic cover that you use to observe numerous LEDs that light up during various conditions and operations.
Lately the system has decided to behave badly. First it started to take repeated Off/On cycles to get it to recognize that the brake was set, and then eventually, the symptom became that the 'Not in Park/Brake' light will not go out. Called HWH service help and also checked the tech guide for that symptom and both sources had me remove a connector on the rear of the box, short a certain pin directly to ground.
That test did not help. According to the tech, and the book, that means the control circuit board is bad. There is no other help offered after that, like a certain relay is bad, or there are cold solder joints. When I removed that box and inspected the circuitry, everything looked good (though I didn't remover the PCB to inspect the reverse).
Any tech's here that might have an idea of what could be wrong with the PCB that I might check before sending it in for repair? Reason is that the RV is down here in Mexico and shipping stuff to/from here can be dicey. And I like to fix things, just helps to have a clue about this issue.
Here's what the box looks like:
And the control:
Thanks for any ideas...
Jim,
I don't think I've ever seen him on here but, over in IRV2, there's a gent known by the user name of "AZ PETE". His name is Paul. He's a tech for HWH and knows every inch of every HWH system. He's not a salesperson. He's just done tons of work for them and he's about as nice a fellow and has helpful as they come. He'll get you on the right track.
The HWH system, as you know, utilizes a ground provided by the parking brake switch. If that switch and that part of the system does not provide a good ground, you're in for a search as to what's wrong, kind-a like what you're experiencing. Good luck.
Scott
P.S. Oh, by the way, be careful with that control box in the picture. ON the right side of the picture of that box, is the "auto level" adjustment. It's a double axis movable component. It's what's used to adjust your automatic leveling sensor. I know you're not "bouncing" around that box but, just be careful.
Scott
