33_Ford's avatar
33_Ford
Hwh leveling system
Hello all. I'm new to this Internet stuff, but I have a problem that I need help with, so here goes. My HWH leveling system allows the left front of my 2000 Itaska to bleed down and become unlevel. There was a leak on that cylinder but that has been rebuilt. However the coach still settles. Any help would be appreciated . Thanks
  • Thanks for the input! All are good thoughts. I was thinking much like Janss, and wondering if there was a way to back flush that solenoid valve in case there might be some debris in it. I have been searching the Internet and no one else has mentioned this kind of problem. I seem to get the unusual ones. Thanks for your responses.
  • If only one jack is rising, it could be a leaking solenoid. I had that problem.
  • check and ensure that the bypass valves by the hydraulic pump are in the fully closed position. The person rebuilding the cylinder may have bleed the pressure off and not gotten the valves shut tight.
