- T_AExplorerI once had a problem with the control panel with the lamps and switch attached. If I pushed down on the panel it would briefly come to life. I removed the cover panel with 4 screws and found the spring contacts between the panel and the circuit board below had lost contact. I stretched the springs slightly and reattached the panel. It's worked ever since.
On another trip I found another fuse hidden in the engine compartment. Good luck. - Pangaea_RonExplorerVehicle transmission in Park
Parking Brake fully on.
Batteries fully charged.
Start Key in correct accessory position.
Optional key safety lock turned on.
These are all things that I have not done in the past?
38,767 PostsLatest Activity: Jun 02, 2013
