mike brez wrote:
dougrainer wrote:
take a 4 gauge or larger jump wire from the Battery cable feed at the pump assbly to the Motor cable lug. The motor should run. If it does NOT, then the 12 volt pump motor is bad. Doug
I took a wire from the hot side of pump relay and touched it to pump and nothing. I took test light with test wire from same hot side relay,test light is on touch wire to pump test light goes out. Take hot wire from my generator battery touch pump and runs.
Maybe your battery, other than genny battery, has an issue? Possibly not enough charge(current) to run the pump and is why you loose power.
-paul
