wa8yxm
Oct 14, 2017Explorer III
You have guessed the usual issue but far as I know there is no adjustment unless the switch has completely fallen apart in which case it will not work period.
Is there an Emergency Brake indicator on the dash? Here is why I ask
On my Workhorse (Chey engine) the parking brake pedal switch has the jacks sensor wire hooked to it. The dash indicator is hooked to a tap off the jacks cable. SO if the dash indicator is ON.. then the Jack sensor lead MUST be grounded
38,770 PostsLatest Activity: Apr 12, 2026
