dougrainer
Jan 07, 2018Nomad
JaxDad wrote:dougrainer wrote:johnhicks wrote:
HWH says to spray with WD-40 and wipe off.
As I stated, cycling the jacks twice a month will be all that is needed unless they get extremely dirty. When retracted, they are immersed in ATF fluid which means you do not have to lube with WD 40 or silicone. Doug
https://www.hwhcorp.com/ml47149.pdf
What will cycling do to help the seals?
Unless the seals are shot the fluid is contained by them, I.E. the wet side is always wet and the dry side is always dry.
It would seem cycling would just expose the wiper seals to that much more debris.
If the MH is moved 4 times a year the wiper seals are used to clean the piston rod of debris 4 times. If the jacks are cycled twice a month the wiper seal is used to clean debris 24 times a year.
It helps run a thin film of ATF by the seals and helps keep them "supple". Seals can dry out. There is no such thing as a "wiper" seal. There are lower and upper seals and both contain the fluid. You are overthinking this. The amount of times you operate your jacks is a none issue. They are designed for thousands of cycles. Doug
