wolfe10
Feb 09, 2014Explorer
Since most filters are on the suction side of the hydraulic pump, probably would not hurt.
Fill the small outer holes (inlets) not center large hole (outlet).
If the reservoir (actually oil level in reservoir) is above the filter base, you can also install dry, but not tighten the filter and let gravity fill it.
38,778 PostsLatest Activity: Jun 10, 2026
