palehorse89
Feb 09, 2014Explorer
smlranger wrote:
My coach as a large, spin-on hydraulic fluid filter mounted outside the hydraulic fluid reservoir for the radiator fan and power steering. I want to change the filter and am wondering if I need to pre fill the new filter.
I is a fairly large, maybe 1 1/2 quart filter so I don't want to cause problems by putting it on dry.
If you pre-fill the new 1-1/2 quart filter.....chances are that your reservoir will not be 1-1/2 qts. low when done. Fill the new filter or add to the reservoir so to be at proper level when done.....
38,778 PostsLatest Activity: Jun 10, 2026
