Fishinghat
Sep 24, 2013Explorer II
I strongly suspect the creaking you're hearing is from the coach adjusting to the change in loading from the suspension system to the jacks. It's normal. As for the wind, I don't know how the wind would cause any creaking noise while leveling the coach, but not before or after. If the noise is there after you've leveled, then the jacks could be leaking fluid back to the reservoir. If so, check the bleed valves to make sure they are completely closed.
Walking around may cause some noise as weight shifts, but you should have noticed the cause and effect.
38,769 PostsLatest Activity: Apr 04, 2026
