B_B_Upch's avatar
B_B_Upch
hydraulic Jacks not working
hello again so I have had great success getting advice on here I figured I would try again. so I have a 96 allegro bay (gasoline) class A that we hare rebuilding. I have had it up on Jacks a couple of times & never had an issue before. this last time I had it up on its Jacks I noticed a little fluid around the front driver side jack. so I figu red it might have a small leak (it was not much). I let it off the Jacks & went to take off & the battery was bad. so I replaced the battery, & went to put it back on the jacks. I hit the levers & I hear a click but that is it.. I can move it in any direction & it just makes a click sound. this is with a new battery & connect to a 30 watt outlet. but non of the jacks come down. I checked the fluid level & or was a little low so I filled it up & still the same thing... any suggestions?
  • Recheck the last thing you did.....Works more times than you would think.:S
