Fishinghat
Aug 04, 2014Explorer II
Since your electric steps also won't work (from your previous post), I'm going to assume it is due to a failed relay. When you turn your key, a relay turns power on to some things (like your windshield wipers) and turns off power to other things (like your leveling jacks). I'm not familiar with your coach, but in my coach the relays look like tiny beer cans with a copper bolt on each side and two much smaller bolts near the bottom. You should have several, perhaps four or more. They eventually wear out, like a starter solenoid on a car. In fact, the look very similar.
Checking them is actually quite easy. Just have someone turn the key and listen. When you hear the clicking, you've found the relay responsible. If they are working, then you'll need to check to see if power is being passed thru or not.
Good luck.
Good luck.
38,766 PostsLatest Activity: Jan 10, 2026
