MountainAir05
Sep 15, 2019Explorer II
Look at where the pump is located and you will see all the hoses coming back to one valve per hose. Those valves control the fluid coming back. Have someone hit store and you have your hand on those valves and one maybe is not clicking. You might be able to see which hose goes to the jack that is sticking. If so hit store and wait till the pressure is lost, then take the hose loose and then the valve and see if it stuck or gum up. With it out and connected to plug, hit store and see if you feel it click. You might have to ground it to the frame for it to work. If it works then check the passage for something in it or use the troubleshoot manual for your system, check the voltage on the pins.
38,782 PostsLatest Activity: Aug 11, 2021
