s_N_s
Sep 16, 2019Explorer
If you know the model of your system go to rvleveling.com and give them a call. The name of the company is Stuart's Services and they are in Elkhart, IN. The number is (800) 826-6267. I've always had the best results from them when having a problem with the jack system. My guess is you have the HWH325 system on your coach. If the jacks are not going up it's probably a bad solenoid which would be located on the pump manifold. There would be four (4) of them, one for each jack. Good luck and hope you get it taken care of.
38,782 PostsLatest Activity: Sep 10, 2026
