dougrainer
Sep 16, 2019Nomad
s N s wrote:
If you know the model of your system go to rvleveling.com and give them a call. The name of the company is Stuart's Services and they are in Elkhart, IN. The number is (800) 826-6267. I've always had the best results from them when having a problem with the jack system. My guess is you have the HWH325 system on your coach. If the jacks are not going up it's probably a bad solenoid which would be located on the pump manifold. There would be four (4) of them, one for each jack. Good luck and hope you get it taken care of.
Note that he states the Jacks DO retract. They just stop when there is no added weight to force them up. So, that means his solenoids are OK. He also opened up the Hydraulic lines at the jacks(bypassing the solenoids). They still did not fully retract and he had to pry them up when in store mode. That always points to bad internal sticking seals. Doug
38,782 PostsLatest Activity: Sep 10, 2026
