enblethen
Sep 17, 2019Nomad
The HWH service manual for the Joystick-controlled 200/210 says to "take the hose loose at the jack, if it doesn't retract, replace the cylinder. If it does retract, loosen the hose for that jack at the valve. If the jack retracts, replace the valve. If the jack does not retract, the problem is the hose."
If it is the jack, you can replace just the cylinder and not the complete jack.
38,782 PostsLatest Activity: Aug 11, 2021
