DSDP_Don
Feb 24, 2015Explorer
I'm not sure if it was Lippert, but there was a recent post about poor grounds on the pump. The pump was grounded via it's attachment bolts which become corroded. Find the pump, use a set of jumper cables and jump from the frame to some metal on the pump motor and try again. Obviously, if it works you need to make sure the ground is cleaned up or a ground strap is added.
38,782 PostsLatest Activity: Sep 10, 2026
