dougrainer
Feb 25, 2015Nomad
big boulder wrote:
Thanks for input. I found operators manual and it is 225 series leveling system. I think it is lack of power to pump also. Now I have some scematics I should be able to check grounds and the inline fuses.That would be an easy inexpensive fix so I've got my fingers crossed. Thanks again!
That click is indeed the solenoid on the pump. The solenoid is NOT closing. You will have 2 large cables on the solenoid. 1 is the battery feed, the other is to the electric pump motor. JUMP across those 2 terminals with a heavy screwdriver. The pump should activate. Stop when the pump activates. There are 2 other small wires on the solenoid. 1 will have constant 12 volt positive when the system is turned on and the other will have negative(ground) when you activate one of the jack levers. Have someone activate a jack lever and you be at the pump. See if that click is from that solenoid. If it is, then replace that solenoid if jumping the 2 large activates the motor. It is possible you have a bad motor, but jumping those 2 large will tell you that as long as the battery side has good 12 volt positive. Doug
38,782 PostsLatest Activity: Sep 10, 2026
