mtrumpet
Feb 25, 2015Explorer
big boulder wrote:
The clicking noise that I'm hearing is coming from directly under the cover plate on the floor. As I mentioned before, when I toggle frt, rr, right or left, the click also changes location. I'm hopefully that it's a bad ground that can be cleaned up or one of the fuses I observed in the HWH 225 series operators manual. I'd be looking now but for crappy forcast- cold and raining. Can't wait to troubleshoot with the new info.
The clicking that is changing locations that you're referring too is probably the directional valves opening to let oil to the respective jacks that you are attempting to lower. However, as the pump is not activating, there is no fluid being sent through the system to lower the jacks. As others have speculated, I'd say that the problem is that your pump is not getting power. After all, you certainly would hear the pump come on if it was operating correctly.
38,782 PostsLatest Activity: Sep 10, 2026
