Executive45
May 16, 2016Explorer III
OP, open your top step. You'll see the plastic storage bin. Remove the six screws and lift that bin out. All your stuff is right there. Make sure you clean the top of the reservoir well before removing the cap to check the fluid level. Since it's exposed, lots of junk adheres to the top. You don't want any debris inside that reservoir.
BTW, attached to that reservoir are the valves that you open to release the slides should one fail....Dennis
38,781 PostsLatest Activity: Aug 12, 2026
