- Sandia_ManExplorer IIWe don't utilize our power gear levelers unless we need to level and/or stabilize our coach. That's us, not worried about flat spots, mice/chipmunks/squirrels, or hydraulic leaks. Haven't researched what Toyo tires or Monaco says about the subject, and frankly don't plan to waste my time. Do what works for you, try it both ways and make your own conclusion. If you were going to store it indefinitely maybe it would pay to be more anal about it, for a just a few months or less would likely not matter either way you decide to go.
- Blaster_ManExplorerI store my coach with jacks down, that's what the owner's manual says and that's why they are there.
- H___EExplorerI store ours with the air dumped and the jacks up. I do not change the tire pressure. On or about the first of every month I run the generator, under a load, and take the coach for a drive on the interstate to get everything hot. So far that has worked well for me.
Ours is stored inside a building and plugged into 20A service. - olfarmerExplorer III think mice are far more likely to climb up the tires and wheels to the axles than to try to climb up a slippery stainless steel shaft.
- Ray_INExplorer IIIMichelin Tire recommends using leveling jacks to support coach weight during long-term storage, AND inflate tires to sidewall listed pressure.
HWH jack shafts are SST and do not corrode/rust. HWH says leaving jacks extended during long-term storage is OK.
As to flat-spotting yes it is still a thing: - Dutch_12078Explorer IIISince the leveling jacks/stabilizers don't reveal any openings into the RV when extended, I don't see mice being attracted to them. That's assuming they could get a grip on the cylinders in the first place to climb them.
- Yosemite_Sam1ExplorerYes mice. It looks like 4 runways for mice to march inside the RV.
- GjacExplorer III
valhalla360 wrote:
Think of the millions of trucks, tractors, cars and other heavy equipment that sit without levelers. Snow, rust and dirt can build up on extender levelers. Retracted levelers stay immersed in hydraulic fluid and are protected from the elements assuming you have hydraulic jacks.
Not a huge issue either way but I would lean toward raising them:
- Flat spots on the tires are more an issue from 40-50yrs ago. Modern tires are much more stable.
- Hydraulics will be under pressure, so lots of time to leak (but really a low risk). FLHTCI wrote:
Hello all,
What’s the consensus on leaving your stabilizers down while in storage?
Ive heard it’s 4 more ways for mice to get into the coach. I also heard it keep some of the weight off of the tires minimizing flat spots on the tires.
Thank you
Sorry, had to laugh. Mice would look at 2 motorhomes and conclude the one with 4 jacks extended is the one to go into:B? IF you have NON powered retract type jacks(HWH and some Powergear), I would extend. But if you have electric or Power down and Power up jacks I would not leave extended. If you have a failure to get retracted, then you have a problem getting the RV to the Service Center. Doug- valhalla360Navigator
way2roll wrote:
The only real downside I ever thought of when leaving jacks down for storage, is if there is a problem with your jacks when you go to take it out, you are stuck. But I guess better to know in storage than while on a trip.
Good point but I come to the opposite conclusion.
Stabilizers are certainly nice to have but not mission critical. Worst case I can spend $30 on a set of aluminum jack stands to get by for a short trip...vs no trip if I can't get them working and they trap the trailer. Also, that means I need to pay someone to go to the rig vs taking the rig to someone.
38,782 PostsLatest Activity: Sep 10, 2026
