garry1p
Jan 01, 2017Explorer
When replacing the power steering pump you can bleed the system by turning the steering wheel (engine running) "all" the way to the left then back and all the way to the right.
Do this a couple of times.
When the brake hose to the wheel cylinders go bad the brakes do not release after you apply the brakes causing that wheel to lock up.
RV brakes require a lot more foot pressure than an automobile are you sure you have NO brakes?
38,766 PostsLatest Activity: Jan 10, 2026
