mumkin
Nov 14, 2019Explorer
NRALIFR wrote:
Is what you are referring to as an “under hood generator” actually one of Balmar’s alternator/regulator systems? Their “regulators” are actually multi-stage charge controllers, and would be similar to a DC-DC converter, except that they are connected directly to the alternator rather than the starting battery.
The underhood "generator" is actually a second large alternator such as are used in ambulances. It is set up to charge the house battery system. My rig has standard AGMs, so the regulator is part of the alternator. If there are lithiums, their more complicated system uses the balmar regulator. Originally Roadtrek was getting them directly from balmar. (I even spoke to them when I needed to reset the one on my 170 after I dumped the lithium system and went back to AGMs) The large alternators are provided by Nation's Starter in Missouri and at some point Nation's starting working directly with Balmar and supplied RT with both. Makes more sense that way...
